adam musick
20 points
Posted on - 10/18/2014
I need to make a website for my child welfare organization. It would have track records and information about our organization. As it would contain track records then definitely is has data base which means I have to use php or sql.Moreover the website should be fully dinamic.I just want a software which uses easy drag and drop features and we can create database in it at a same time. Anyone knows such kind of software please help.
Need best software for web devolpment
Dear Adam Musick,
Your question is self explanatory and telling me about the answer.
The shortest answer of your question is you should use any one of the following CMS (Content management System) softwares.
1. WordPress
2. Joomla
3. Drupal
Lets discuss each of them.
1. WordPress:
WordPress is open source and available freely. This is very user friendly, powerful and search engine friendly software.
Almost every 1 website amongst 4 newly created make use of WordPress. You can design a dynamic website in a day using WordPress. It is best used for creating blog, corporate sites and small and medium sized business sites. It also supports thousands of different plugins to make work easy, elegant and powerful. CNN and Forbes are two major examples of using WordPress.
2. Joomla:
Joomla is also free and powerful CMS. The main power of Joomla is its ability to make social websites easily and quickly.
But it also a little technical than WordPress. It is best described a compromise between WordPress (almost no technical knowledge needed) and Drupal (most technical). Harvard University website is built using Joomla. It is usually used for ecommerce and social networking website.
3. Drupal:
Drupal is also a freely available CMS software. This is most quick, efficient than all CMS but it requires a good (although not at expert level) understanding of HTML, CSS, JavaScript, PHP, MySQL . You can create any type of website using drupal. Linux official site is the best example of drupal use.
