Need Blog Template like Shallee Template
I want to make my blog like this blog (shalleem carthur.blogspot.com/2011/01/ strengthen-your-story-through-your.html) remove spaces in URL. Please guide me.
Hi Gulshan,
If you want to make your blog like Shalle blog then best solution for you is to use same template that is used by Shalle. You should use template because it provides you Graphical User Interface than trying to edit the CSSand HTML in the template. For getting this template Go back to Shallee Mcarthur’s blog and scroll down to the bottom of the page. There you will see links for giving credit to the creators, publishers, etc. There you will find a link where it says “Blogger Template by ThemeLib.com” click the “Blogger Template” part and it should take you to this site
This is most likely where Shallee Mcarthur got her template. On that website, click the Download link and save the file to your computer. To use that template, go to your blog
· Click Design
· Click Edit HTML
· Press Browse and navigate to the template you downloaded earlier
· Press Upload
· You may see some warning about some widgets not being included in the new template you are trying to upload. Just select if you want to Keep the Widgets or Delete them.
· Once the upload is successful, you’ll see a message saying “Your changes have been saved. View Blog”
Also you can download Blogger templates from various websites. Just Google “blogger templates” or 'blog spot templates” and you will see that there are numerous websites offering templates for your Google blog.
You can download these templates free of cost. These websites have a side selection of templates you can choose from. Different styles such as templates that have 2 columns, 3 columns, footer widget spaces, ads enabled, adjustable widths, even professional looking templates that you can use. They also come all sorts of colors such as black, red, blue, brown, green, etc.
Good luck!
