chavez sims
Posted on - 10/05/2012
I have hp nc6400 laptop i am using win 7 in it but i have a problem with Bluetooth driver whenever i try to connect it says Bluetooth driver is not installed. please give me a URL from where i can download Bluetooth soft for hp laptop.
Need bluetooth soft for hp laptop
Go to the HP website here. Type your laptop's model or product name and then click the Search button beside the text box. Click the model name of your laptop below and you will be redirected to the Download Drivers and Software page.
Select your Operating system below and the list of all the default drivers installed on your laptop when you bought it will appear. Select the driver for the Bluetooth and click the Download link.
After the downloading process, run the installation and then restart your computer.
Test the Bluetooth if it's working. You can also click this direct link to download drivers for Windows 7 in case it is not available on the first link.
Hello Chavez,
Your Laptop model seems to be very old so the manufacture has ended the support for this model.
However you have an option to download and install the drivers available to the manufacturer site for windows vista.
As most of the windows vista compatible software are also compatible with windows 7.
Given link where you can find all the drivers for your notebook.
