Is there Helical gearing system available? Which operating system and how many disk spaces are required in G27 Racing Wheel? How many USB port is needed to integrate this? Which platform compatibility is required? Which software is required for G27 Racing Wheel? Is there any indicator panel? How many paddle shifters are there? Thank You
Need a brief and useful information about G27 Racing Wheel
Hello Adam!
1. Is there Helical gearing system available? Answer – there is helical gear system available in the market right now. Emerson offers this type of system, they can be on perpendicular tubes, fine-tuning the turning angle by 90 degrees. Also in G27 Racing Wheel helical gearing system’s applied to avoid noise and for full driving experience.
2. Which operating system and how many disk spaces are required in G27Racing Wheel? Answer – Windows® 8, Windows 7, Windows Vista®, or Windows XP, 20 MB of available hard disk space, USB port, and internet connection for Software download.
3. How many USB port is needed to integrate this? Answer – there are 4 USB ports available for this system.
4. Which software is required for G27 Racing Wheel? Answer – along with this, bundled with driver and software to make it work with your computer.
5. Is there any indicator panel? Answer – they have RPM/SHIFT INDICATOR LEDS for indicator panel.
6. How many paddle shifters are there? Answer – there are two steel paddle shifter located under the steering wheel.
