C++ Programming code for implementing integer and floating point division
7060 points
Posted on - 03/14/2012
Hello Experts! I need to write a program that will evaluate the difference in implementing times between integer and floating point division. As an output for testing the program, the operation should be implemented a hundred thousand times and then try to equate the difference in running time. The program must be in C++ Programming Language and the codes should be complete and running correctly. Thanks.
