Hi expert, I need some call log system templates for windows 7. Templets should create using by Microsoft access 2003. Please send the download links for windows 7. And send some helping tutorial explanations for how to download it.Â
Need call log system templates
Hello Joseph K Carpenter,
               You can also do that task by using Google documents. Here you can online store all your data so that you can access it any where when you want.  You can also design this one in access database. I am giving you a link from there you can download a template it is free of cost and you can also introduce some additional features in it by giving them some money if you do not know how to add.
http://softwaretopic.informer.com/microsoft-access-call-log-template/
With the call log templates that you need you can try the Desktop Call Tracker that assists with assigning and tracking calls using a dynamic access template that you can edit at any time. Its gives you the options to check by customer, staff and also calls. You can also add priority, status and to whom it was assigned. The reports can be generated in real time e.g. open calls, closed calls etc. The link contains a portion to download and some screen shots of what to expect.
