Need to choose a PDF to excel converter to download for PC
I use Windows 7 in my PC. I want to download a PDF to excel converter which would be the most supportive one. I don't have Microsoft excel installed in my computer. Now which one should I choose?
Thanks
Best Answer by Luker Malcom
Answered By 5 points N/A #142069
If you are looking for a good PDF to excel software that can work even without Microsoft Excel or Acrobat Reader, then I suggest ADEPT PDF TO EXCEL CONVERTER. It has stand-alone software so there no need to use any Microsoft Office tools or Adobe Acrobat Reader. It also resized your PDF file so it will fit on a standard Word page size. You can also convert batches of files at a time because it supports multiple conversions. It can be installed in Windows 98, ME, NT, 2000, 2003, XP, Vista and Windows 7. Adept allows you to try their converter for a trial period and if you decide to continue beyond trial period, you can purchase their converter kit for only $49.95. To know more about Adept, visit this website: http://www.adeptpdf.com/.
Answered By 5 points N/A #142068
You are looking for PDF to Excel Converter for window 7. You can directly convert the PDF documents to Excel online from the mentioned link below:
https://www.pdftoexcelonline.com/
If you want offline PDF to Excel Converter for window 7. You can download from the mentioned link:
http://www.pdfexcelconverter.com/
Just click on above link then click on free download link and downloading starts.Enjoy PDF to Excel Converter
Best,
Fenster Maxine
