Need cleen face edit with Photoshop software, help!
Hello Friends I need to edit some picture which has pimples on their face. I am very new with Photoshop. Do you know the way of clean face editing process with this software? Please help.
Using Adobe Photoshop of any version like CS2, CS3, CS4, CS5, 6.0 Â or any other version. There are two ways on how to eliminate the pimples on their face:
If you want to use one of these tools, select the tool and press ALT + the sampling point on the area you want to copy then click.
See attach picture for reference.
Best Regards,
Jeffrey Vidanes
Face is the key factor on any photo. There are some freeware software’s which lets you retouch and edit your photo like a professional. Lots of free software helps you edit your image and clean up too. Some online software’s also helping you to edit photos. Â
If you want software for editing, you can try ‘Photo Face Changer’ software. It’s freeware software which lets you edit your photo like a professional. You can edit whatever you want. Just go with
https://software-download.name/face-change-software/ this site and download.
Install it.
Enjoy your edit.Â
