Need color code for USB mouse confusion
I have a mouse with wires all out. I need the color code to connect it again. The colors are black, brown, pink and orange. I need the color code for usb mouse to connect them to my usb port in my computer.
Hi Gregory Manilov,
I think you are in little bit problem for choosing and knowing the color code for your newly bought USB mouse.Don't worry. I am going to describe for your USB mouse color code for use in your pc.Follow the following indication and you will get your information from my suggestion.
VCC pin in red color and +5V, D- pin will color of white and data – . D+ pin is generally Green in color data+ .GND, color is black and signal ground.
