Need a comics reader Joomla sites
I 'm interested in Joomla comics. I need a software or something like that to read and index the pages Joomla comics directly from the site. If you know about a software which could help me please inform me.
Hello Denise,
There is a working solution to your query.
Since your interested in using Joomla, ComicMan seems to be a good option for you. This software supports many features and will display your comics in an attractive and organized manner.
You can visit this website:
https://extensions.joomla.org/extension/
for more information about ComicMan.
If you are willing to work without using Joomla then you can also check out ComicCMS as well.
Link: http://comiccms.com/
Hope this solution helps you with your work.
Regards
“Ridoy Albert”
