Need Commands To Export Active Directory Group Members.
Hello all,
I want to Export the Group Members of the Active Directory to a Text File. I don’t know about the command that I have to use to perform this task. Someone, please tell me the commands to Export Active Directory Group Members.
Answered By 230 points N/A #112624
You can use two methods to Export the Active Directory Group Members to a Text File. “Net Group” Command and the “DS Query” can do the job.
The command to Export the Group Members using the Net Group is: –
“Net Group Name of the Group /Domain > Output File’s Name.”
If you use the DS Query Command, then the command line will be: –
“Dsquery group-name Name of the Group | Dsget group-member > Output File’s Name.”
You can see the screenshot for the Commands, where “Group Name” is the name of the Group, and “Memberlist.txt” is the name of the output File.
