Need to connect FLV clip, Any software ?
Dear Experts,
I have certain clips in flv format. I want to connect them together as one long clip. Is there any software which acts as flv files connector?
Also briefly tell me the use if there is any.
Thanks in advance.
Best Answer by Martin Trish
Answered By 0 points N/A #165275
Hello Rosellas
What operating system you are using. If it is XP then use Windows movie maker. Use movie maker to connect them all  to form
Full length flv file. Considering you are using windows 7 then install windows live program and now use windows movie maker.
You can use the Software but using movie maker you can add another audio file and can delete some portion of a file that you do not want.
Answered By 0 points N/A #165276
Hi Rosellas Phillips,
I have read that the problem you are having with the .flv files, and i have experienced the same issue as before when i was downloading video from YouTube.
I have an excellent Converting Software named FormatFactory, with which you can convert your .flv files into any other files.
You can download it free from here : https://format-factory.en.softonic.com/
Hope i helped you.
Cordially.
