Hello, I have images on my computer. So I need to convert multiple GIF to CBR. I used Video X software, but it was a trail version and it is very difficult to do it. So I need the best software for convert multiple GIF to CBR. Please suggest me some softwares. Thanks.
Need to convert multiple GIF to CBR
Hello there! Actually you do not really need any software for that. If you are using Windows, you can simply right click on the file or gif that you wish to convert to CBR (Comic Book RAR) then click 'Send to -> Compressed ZIP'. After that make sure you're file extensions are visible. To make the file extensions visible, you can google for a simple tutorial. Once you have set that, go to the ZIP file that you made earlier form Send To, and rename it from example.zip to example.cbr. Hope that helps!
Hello Jerrny Slaterable,
For this purpose you have to install 7-zip software it is one of the best software for your required conversions and you can get it easily from the below link. For 32 bit window you have to download 32 bit version but if you are using 64 bit then you have to download the 64 bit version. It is free of cost and also you can get a complete guide on how to us it in the manual after installation.
http://www.7-zip.org/
