doblema
Posted on - 07/27/2016
Hi everyone,
My Client has sent a Drawing in the form of a PDF File. I want to add some more features to the depiction. For that, I will have to open it with Corel Draw. Someone, suggest me a tool to Convert PDF to Corel Draw.
Need To Convert PDF To Corel Draw Using An Online Tool.
For most of the Online Conversions, I propose Convert Cat. The Interface is very simple to use, and the time taken to transform the file is also very less. It supports almost all the File types.
1) Open https://www.ipset.in/.
2) Choose the “Choose Files” button, and upload the PDF File that you have received via Email.
3) Select “cdr” as the Extension from the Drop-down Menu.
4) Enter your Email ID, and click on “Convert”.
You will get your Corel Draw File in no time.
