Need to converter split channels of wav
Hi guys,
I have a wav song. I wonder if we can split wav sound to channels. Which program I can use to converter split channels of wav. Where can I download that program?
Hi guys,
Download and install dBpowerAMP program.
Open dBpowerAMP on your PC and go the program's main browser window and select the multi channel WAV file that you need to split.
Then right click on your WAV file and choose “Convert To” and then select “Channel Split” (This action will save each channel of the WAV file).
Hope this solution will be helpful.
Thanks & Regards,
Mckinney Ma
Download slice audio splitter. It has ten features and it can split FLAC files, OGG and much more.
Use the tutorial available here to learn how to split your desired sound files into separate tracks.
