Need a cookie cleaner software
Hi everyone,
I frequently use the net, so there are many cookies store in my computer. I want to clear them. What is the best scanner cookies software to clear them? Can anyone help me to find this, thanks!
Hi everyone,
Hi Brenda Lopez,
It's very important to regularly clear your browser cache memory by clearing cookies. There are many software to help you achieve that but my best cookie cleaner is "Crap Cleaner". This software helps you clean cookies.
Download it from their official website http://www.piriform.com/go/ccleaner.com
Once on the website, find the download link.
Thanks,
Ford Smithkings
For cookie cleaning I highly recommend for you this one, it is called “CCleaner”. It is one of the best tools for windows in cleaning cookies, it protects your privacy online and makes your computer faster and more secure. Just download it from this site http://www.piriform.com/ccleaner. I never had any problems with this software, try using this one.
Hello Brenda,
The best way to clear cookies and cache is to clear them from the web browser tool tab. This will completely remove your history plus your cookies. I will not recommend you to download a third party software to install on your computer when you have built in function in your system. This will save you space and risk of getting viruses will get minimized.
To clear all the cookies, cache, history and saved passwords. Please follow the following steps:
For Chrome:
1. Go to settings -> tools -> clear browsing data.
2. Check on the boxes you want to clear.
For Internet Explorer:
1. Go to tools -> Internet options -> clear history.
This will solve your problem.
Hi Brenda Lopez
There is another Techyv post which is also addressed about this issue. Pay a visit that page and get more information.
Which one is the best cookie cleaner for Firefox in Windows XP?
Notifications
