Need a couple of Samsung Wave Sensor motion games
I need a couple of Samsung Wave Sensor motion games, I don’t know where to download such games for free.
Please advice.
Please advice.
Wave sensor motion games are nice, but it’s quite difficult to find them for free.
Try this link, I think you will find what you are looking for.
You are looking for sensor motion games for your Samsung wave.
As per your phone specification you are using BADA OS.
You can download sensor motion games for your Samsung wave from the link:
But, I recommended to you, You can try the best sensor motion game which is supported by Samsung Wave (Bada OS).
You can download the Final Strike 3D from the link:
I hope it will helpful.
Thanks!
