Need to create batch file speed test internet connection?
kent woods 30 points N/APosted on - 11/30/2012
I am running Windows 7 Ultimate and I would like to know how to create and code batch file speed test to detect the internet connection speed of my computer. I've been browsing the web whole day just to find the code but can't find it. I wonder if someone could give me an answer here. Thank you.
You can create it in your by opening the Window of the computer. After you open it, press start and search for the code batch file. Click it and there's an instruction in the given words after you click it. Click the save button and its automatically detect the internet connection on your computer.
No, I don’t think you can create a batch file that can check the speed of your internet connection. You can create a batch file that can ping a website to check your internet connection’s status but that’s about it. There are no available commands in DOS and in Microsoft Windows that can check the speed of internet connection.
On the other hand, though you can’t create a batch file that can perform a speed test for your internet connection, you can install a program that can do the speed test. Download SoftPerfect NetWorx. Follow the instructions to download and unpack and then install it. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. This is the last free version of the software.
The succeeding versions have been commercialized. Price starts at $25. If you want to try the latest version, go to SoftPerfect NetWorx Home Page. Users can download the full-featured trial version which works for 30 days. To check your speed, right-click the NetWorx icon on the system tray then select “Speed Meter”.
SoftPerfect NetWorx Speed Meter
Another way to do a speed test is with Ookla Speedtest using your web browser.
1....
