Hi friends,
I am doing statistical works I need to use bar, pie graphs work frequently, so I am in need of data analysis and generator software. How can I get free full version of the data analysis generator software. Is there any way to do this data analysis generator online. Help me.
Thanks in advance,
Jusstin
Need data analysis generator online
Here are some of the software or online help you can use for your data analysis.
PLOTLY – a collaborative data analysis and graphing tool
This is an online data analysis tool. You just have to give your data in a format that it supports and you can have the graphs (scatter, line bar, and more). Go to their website by clicking the word PLOTLY above. Then click on "Try out the beta" on that page so that you might see how it works.
There are other software that might help you but the you will find out that the software you download are not full version because they are only trial versions.
Hi Justin,
There are free data analysis and graphing software available in the market namely the SigmaPlot and OriginLab. Both software offers great features and functionality in terms of data analysis and producing graphs. Also, both software are free to use and download. In addition, each software has add-on functionality that you should use based on your needs.
To review and download the software, kindly click the link below.
Sigma Plot Data Analysis and Graphing Software – This link will guide you through the official website of SigmaPlot Data Analysis and Graphign Software. It contains the features and functionality of the software as well as the tutorials on how to use it.
Origin Lab Data Analysis and Graphing Software – This link will guide you through the official website of the Origin Lab Data Analysis and Graphing Software. It shows the different types of graphs that you can use and modify.
Ware
