I've got problems regarding usb programming in delphi. I just started using this last week, and I'm really confused right now. Do you know any code written in delphi (delphi 7 suggestions would be very much appreciated) that I can use to take control of usb devices? I think it would be very helpful for you to share any delphi usb example code you know.
Need for delphi USB example code
Hi Lenore. Regarding on your query about USB programming in Delphi 7. Codes are not written in Delphi 7 but you can download USB software for Delphi 7 and to take control of USB devices. For example Disable USB ports tools 1.0.1 it disables USB ports tools to help you or your system administrator to control USB storage such as USB, Flash disk, USB disk, IPOD etc. You can control a standalone computer or many computers on a computer network. For tutorials and the codes that you are asking you can go to top.windows9download for the rest of it. I hope it helps.
Greetings,
I understand you are looking for a Delphi 7 codes for creating a USB controller.
Here's one. It's a simple USB controller written in Delphi, which enables and disables USB in windows, along with the codes. It may not be exactly what you are looking for, but I believe it's a good start.
I will not take credit for it because I didn't write it.
The link may not work after several months.
