I have to create an autodesk alias design users guide in my Apple Mac OS.
My friend told me autodesk doesn’t supports to Mac OS.
So experts I need to design user guide in my Apple Mac OS.
Please suggest some ideas.
Need to design an autodesk alias users guide
Good day!!
Alias design helps you maintain design you can read recommendations in the user guide, the technical guide or the installation guide for design.
Please check guide line link I believe that it will be help to go-ahead.
Check the link design user guide pdf.
Best of luck.
Thanks
Hi Vivian,
You can navigate the Autodesk Products website for the details
1) Download the pdf file which provides information for new users to Alias software. The guide can be downloaded from the Autodesk link
2) The ICME transition guide 2011 is a PDF file that provides information about the tools and techniques required by professionals through the ICME transaction link
3) You can learn about the alias products through the online documentation for tools and menus
