Need digital player for tv
I need digital player for tv which will play every modern file format multimedia files stored in the local storage device. It must be high definition multimedia player. where can i find the digital player for tv ?
Dear Laura,
If you are connecting your laptop or desktop to your TV to play high definition movies, VLC is the most popular and the easiest player to use. To download it, kindly follow the instructions below:
– Go to http://www.videolan.org/vlc/download-windows.html
– Click on “Installer Package” to download the executable file
– Save it and install it on your computer.
The said software can play almost any file type: MPEG, MP3, MP4, MKV and a whole lot more.
Hope this helps,
Curtis
