jaycepierce
10 points
Posted on - 09/03/2012
Hi Experts,
I need an amiga ebook reader for my psp and computer.
Is it possible for me to download it in my psp and computer?
Give me some tips and links if there are.
Instructions are much appreciated because I really need this as soon as possible.
Thank you.
Need to download amiga eBook reader in my psp
Hello Jayce,
Yes you can download the Amiga ebook reader for your PSP.
The following are the instructions that will help you download not only amiga reader but also any other application that you may want to use on your PSP:
First of all, you will need to unzip the files MPH Downgrader.zip and EBOOT_1.50.zip. You can do that using a program like WinRAR, or WinZip. After that, you will need to open up the PSP folder and then you will enter into the Photo folder. Once there, you will need to copy overflow.tif over, and then remove from the MPH Downgrader folder, making sure that it is kept in the Photo directory and not in a subdirectory.
Next, you will need to backtrack to the PSP directory and after that enter into the Game directory. You should be able to see two strings of letters or numbers which indicates as something has gone wrong but this is and start it up. After that you will need to locate prompts. Turn the power switch up until it fully turns off, and then turn the PSP back on. If you get an error. You will need to press the "O" button and it will restart after rebuilding the system data.
Once that has been done you'll need to figure out what to add with your brand new open-ended BIOS.
Carl
