Need to download ping tools for Linux (Mac OS X)
Dear,
I'm a Mac OS X user. I want to download some ping tools for Linux from any website. I need to know, from where I can get those. This is urgent. I would like to get some help ASAP.
Thanks Â
Dear,
Thanks Â
Hello Garrick Sanderford,
Good day!
It's good that you have posted your concern on this site. Regarding your concern about downloading ping tools for Linux, I have search some sites that may be of help. You can check on the links below:
Have a nice day and good luck!
Rios Louise
Super Ping Pro is an application for your MAC that lets you ping IPs. Just type the IP do be pinged, and specify the number of times to ping and click on "Ping" button. Consider that you want to save the ping result. Just go to File then Save. You will be able to save the ping result in '.txt' format. You can open it with any simple text editor you want.
Download Super Ping Pro tool for your MAC OS X from here.
