Hi There!
Now I am in a serious problem. Today I setup my windows. For installing driver disk I start finding in my home. But I cannot find it.
After sometime I ensure that I have lost it. So I mean that it is the most problem for me.
Now my windows has no sound and no chipset installed.
So I need all drivers.
My PC configuration: Intel dual processor, Motherboard name: Elite ECS Motherboard, RAM-1 GB
Please help me.
Drothy
Need driver disk for windows
Hi!
Nevertheless, drivers are very much important as they are special softwares which directly communicates to our computer hardware and if they are not properly installed, they may lead to serious troubles in the smooth working of the computer.
As you have mentioned the configuration of your PC, I would like to suggest that you use any latest version of Windows XP as there are numerous built in drivers are already attached to it and it is based on plug and play technology. It identifies all physical components of the computer itself. Further, you may ask your computer vendor to provide a duplicate of your drivers otherwise installing windows XP will suffice.
Hope it benefits you.
Trevor
Find the exact model of your Motherboard. Your Motherboard model is written on the board surface in big letters. You can also find the exact model of your Motherboard using utility tools such as CPUZ. Find a program or utility tool like CPUZ and download it on the internet. Run the program to find the exact specification of your Motherboard and all other peripherals.
After finding the specification of your Motherboard, search them on the internet and download for the driver that suits for your operating system installed. Let’s say your operating system is windows 7, download a driver for windows 7 only.
Or better to visit the ECS website.
Windows is bundled with various drivers that automatically installs when you install your operating system and also, when you purchase a new motherboard, it usually comes with installation disk. You did not mention the exact model of your Elite ECS Motherboard so we cannot provide the exact download links for the drivers you need. However, you can go to their official website and have a look by yourself for the exact drivers you need. Just click on the link below:
ECS Elitegroup Motherboard Drivers
