Need drivers blackberry curve Windows XP
I have recently purchased blackberry curve but I don’t get the driver CD with that I have searched all over but I am unable to find it now I have been looking for drivers blackberry curve windows xp version
Best Answer by Laz Zebbena
Answered By 0 points N/A #198699
Hi, Steven M Doud ?
 Follow the link below to download the desired software.
1.       The software download link is below:     ttp://www.freedownload3.com/software/blackberry_curve_driver_windows_xp.html
Thanks a lot.
I hope it will
Answered By 0 points N/A #128744
If you don't have the CD, you can download the Blackberry Desktop Software. It manages the link between your computer and the BlackBerry device. Various versions of this software are available and you need to check their minimum system requirements.
You can download Blackberry Desktop software from this link
Choose the  software version that is compatible with your system specifications
Don't connect your phone to your system before or during the installation of software
Laz Zebbena
