Need a Email Program with Dutch Version
For emailing in huge amount, I am using G-lock Easymail Language Pack, some languages are installed by default at the time of installing. But I need the dutch version which is not available with the default install. Can anyone tell me whether dutch version is available with Easymail? If not, please suggest me a good email program with dutch version.
Thanks
Answered By 0 points N/A #158252
The Language Pack includes the translation of G-Lock EasyMail interface into the Afrikaans, Albanian, Arabic (Saudi Arabia), Croatian, Czech, Dutch, Finnish, Greek, Indonesian, Malay, Portuguese (Brazil), Romanian, Russian, Slovak, Slovenian, Spanish (Argentina) and Turkish languages.
With ActiveCampaign you can easily send email campaigns, auto responders, and more in ANY language that you desire! The character set and encoding options allow you to send in the format you need to ensure that all of your characters are displayed properly for your subscribers. Additionally the entire ActiveCampaign administrative and public section uses a central language file – so you can easily translate the software (or use one of our included language files.)
