Can I make and receive calls using a computer or regular telephone? Can this set up into an internet connection and WI-FI? What is Magic App? What is the difference between Vonage and MagicJack? Can I get local number portability by using this? Is there any un-installation method to uninstall software? Thank You
Need an exact idea of Magic Jack and its workable features
Hello EarlLShryock!
There are several web applications that provides access in making outgoing calls using computer. One is Google Voice. You’ll just need to have Google account. Magic App is also use for Android phones to make free calls. You can make calls to other Android phones, iOS phones and tablets that do have same application installed in it. Both Vonage and MagicJack supports VOIP within US.
The adapter from Vonage is for free while MagicJack sells it with additional charge but with free calls around US. MagicJack comprises much cheaper plans rather than Vonage. Since MagicJack provides at least 6 months subscription while Vonage takes monthly charges and will cost you a lot than the rival. Please be reminded that both carriers ports your old and landline numbers but they have to check if your number is portable, if it’s not you’ll have to get a different number. The software provided will give you options to uninstall it. This products were based in general practice that if the end-user decided to terminate the services, it always provide convenient way to remove it from your devices.
