Need an excellent offline logo creator for free
Hello Friends,
I need few logos to be created by myself. I am not an expert in any Graphic software. My friend suggested that we can have online and offline logo creation software in internet by which we can create excellent logo. Please help me to find an excellent offline logo creator, which can be downloaded for free from the internet.
Thanks,
Goldie Bond
Best Answer by Alex A Gonzales
Answered By 0 points N/A #156858
Dear Goldie Bond,
You can try the tool for freely design the logo. The logo is as simple using this tool. The software Company Logo Designer  is used to design Logo in offline. You will get 25 more design templates available in the program . Just install this Software and design the logo easily. You have to click the logo design you like.
Pattrickk White
Answered By 60 points N/A #156859
Hello Mr. Bond,
There are some good tools available to create logos. You can design logos by yourself and no need to have knowledge about graphics. Check out these free softwares :
The Logo Creator : Create and modify logos with more than 200 customizable templates, import images and much more.
Free Logo Maker : Make professional looking logos, banners, buttons etc in many popular formats.
LogoSmartz : A very simple and easy software to create and design logos.
If you need more options then check out this Top 10 Free Logo Maker Software review. Hope this helps.
Best regards.
