In need of experts’ help in outlook express rename folders
Hello guys! I am really in need of your help in outlook express rename folders since I am a newbie of this software. I really need your guidance for this, thank you!
Hello Centic,
As you are new to outlook express I can understand your problem and I
have process to teach you how to rename folder in outlook express. Here is the solution:
1. Right click on folder which you want to rename in outlook express.
2. Choose “Rename"" from list.
3. Enter name you want to enter.
If still you are having some trouble, then follow this link.
Edward.
Hello! I have red your question. I think you are a newbie in MS Outlook. Well, to make rename folders in outlook express, you have to maintain a process. Firstly, select the folders in outlook express and right click on it. Then select rename option and the dialogue box will be appeared. After that, you have to write the new name and press enter. In this way, you can rename any of the folders in outlook express.
