Need an explanation about php frameworks
Hi guys,
I have a doubt about PHP frameworks,please anyone can explain me “what is PHP framework” in simplest form
Hi guys,
Hi
PHP framework is nothing just a area in which you are working like you are working in its classes or you are working in it OOPS programming so these are the area related things. Through which frames you are working and how you work in these frames are basically called framework of the PHP.
It is very simple thing how to get the information about the knowledge of the things that getting very wrong. So the PHP framework is how to tackle the things in the limit of PHP language and which version you are catering this information is basically PHP framework.
Hope this solution will help you getting out of this problem.
Hello mila,
In a PHP Framework you can easily develop web applications. You can also say that if u need a structure or platform where you can easily work then this is what you need. If you use a PHP Framework, then you can save your precious time, you do not have to write repetitive code again and again, and you can build applications rapidly.
If you do not have a PHP framework, it is much more difficult to develop applications because you will have to repeatedly code a lot of PHP. You will also have to execute the connection between your database and your application by yourself from start. Meanwhile, using a PHP Framework makes it easier for you to ensure this connection
There are plenty of frameworks today in a market , you can choose and work upon a framework which you find comfortable and worth working with.
There are frameworks like cake PHP, codeIgniter , zend ,Prado etc.
