Need to export lion VPN configuration
Experts, help needed to get with this. Is there a way to export lion VPN configuration? Just to make it easier to reconfigure instead of copy and paste procedure. Thanks so much.
Hello Skylabreonna,
You must try this method to get the solution for what you asked. Follow these steps:
1. On your old system, go to System Preferences
2. Network
3. Select VPN
4. Click the option “COG” at bottom left.
5. Select “Export Configurations” and save it to the desktop.
6. Copy to eject-able media/USB/pen drive.
7. Insert that eject-able media/USB/pen drive into your new system.
8. Open System Preferences.
9. Network (provided the correct type of VPN service must be added)
10. Select the added VPN service and click “COG”.
11. Select “Import Configurations” and choose that specific file that was originally exported.
Post back if this really helps you. Thanks.
