Need file sharing cloud app for business
Hi there,
Between Zumodrive, Dropbox and SoonR which is the best file sharing cloud app for business use?Â
Hi there,
You mentioned three, though cloud has also two more efficient and popular file sharing apps in their store.
They are sugarsync and sendspace. Between Dropbox, SoonR, and Zumodrive, I suggest you to use Dropbox.
Because there some more effective features in Dropbox than the other two.
Offensively it’s most useful feature is that, any file you save to your Dropbox, instantly it saves to your PC, smartphones and Dropbox website.
You can get free 2GB of Dropbox cloud storage.
You may expand your subscription up to 100 GB to transfer your file anywhere.
It makes availability of your all files into the secure Dropbox website.
It has the capability to work with Windows, Mac, Linux, iPad, iPhone, Android and BlackBerry.
So where you are, what does you use, you can get the advantages of this cloud apps.
By having this you can get your file even if you haven’t any connection anytime.
So you share your file for any type business purposes being anywhere you are.
By keeping all this in mind, I think Dropbox is the best solution for you.
Don’t limit yourself to the three cloud service providers you mentioned since there are lots of cloud storage providers in the web that you might find interesting and offers better service and features.
One example is the True Image Online from Acronis.
It is a cloud storage service that will give you 250 GB of online storage space that you can use for your backup needs. It costs $4.99 a month but if you will have a 1 year subscription, you can get it for only $49.99 a year. This will give you a savings of around $9+.
And the good thing about subscribing is that 1 single subscription can be used by up to 5 computers and not only that you will also get an additional 1 month free subscription.
For a better understanding of the service, You may visit.
