kent woods
30 points
Posted on - 10/31/2012
Hi
I got a new acer laptop as a gift from my aunt. In the manual there is a new technology called signal up. I found more derails about this from internet but there is no wireless network in my area. So is it possible to use this to access internet through my local wireless router?
Thanks
Need to find driver for signal up wireless internet connection.
Yes you can & first you need to switch on your inbuilt wireless network device on your Acer laptop in order to detect wireless networks available within your coverage area. The signal up technology usually requires the correct drivers in order to work properly therefore you need to check if the wireless drivers installed are compatible with the signal up mode. Its hardware related as a form of WiFi, PIFA antennas that are on top of the screen that help to detect wireless networks within coverage area.
Therefore if you search through WiFi and detect wireless networks, that means your Acer's signal up antenna is working properly thus you should be able to access internet properly.
You need a service provider to solve this issue. Many companies provide this type of services and have coverage in a specific area. You can find these service providers with in your area or region and you will be able to setup a network.Â
Smith Thompson
