I want to buy a Gamepad for use on a PC which is going to be in my living room where it's not simple to use a mouse when playing games, is it possible to use a digital/analogue Gamepad and activities like first person shooters can be managed with the analog sticks instead of the mouse? Can anyone recommend a Gamepad with a good battery life and Wi-Fi.
Need To Find A Good Gamepad To Replace Gaming Mouse
Hello Chloe Victoriay,
I would suggest using Xbox 360 Wireless Gaming Controller for Windows for First Person Shooters or anything else. Basically, anything that works on Xbox 360 will mostly work on PC.
For fighting games I would suggest using an Arcade Stick or a Pad, depending on your preference. If you like an Arcade Stick then I would suggest Arcade FightingStick made by Madcatz.
And for pads, I would suggest the FightPad also made by Madcatz.
If you love playing games but sometimes you find it hard to play with a mouse, you can always buy a gamepad for your computer. Gamepads and joysticks before connect via the game port but modern gaming peripherals nowadays support USB connection. If you need a gamepad for your computer, try checking out Black Wired USB Gamepad For Windows.
The USB cable that connects the gamepad to the USB port is around 1.4 meters. The gamepad supports Windows XP, Windows 7, Windows 8.x, and Windows 10. This is a plug-and-play wired game controller similar to the PlayStation game controller except that it doesn’t support vibration. Check details for shipping. It costs $9.50. Item is located in Beijing, China.
1....
