Need to find smallest video converter
Hi guys,
I have some avi files and I want to convert them to mp4 files. Can I do that? Please help me to find smallest video converterto fulfill my need.
Thanks
Hi guys,
Thanks
Hello Devon,
Have you ever tried Any Video Converter? The best thing about this freeware is that it can convert any video file into any format you need, The converted output is always the same as original one. It serves as Video splitter too and very easy to use.
To convert .avi into .mp4 follow the following steps:
1- Download and install Any Video Converter from this link: http://www.any-video-converter.com/products/for_video_free/
2- Open Any Video Converter and click on Add video Files.
3- When the file is loaded you will see some details on your right pane, Set output as .mp4 and click on Convert Now button
5- Your video file will be saved in your output folder.
This will do the job for you.
Thanks.Â
