jeviery ero
20 points
Posted on - 02/08/2013
I have worked with different type of database wrt different applications now I want to create an application package interface for my client so that they can maintain their data and information like country, time, locations etc so it means I have to create a dictionary program for it.
I need a formatted dictionary SQL dump pattern or some reference kindly suggest me some?
Need a formatted dictionary SQL dump pattern
I can give a probable solution.
Actually to be honest it is a direction rather than the solution.
You can go in this hyperlink here and may find a solution.
Hello Jeviery Ero,
Maintaining the data fields you mentioned is not a big task.
You can maintain in any database pattern, and there you can create your own fields.
Please go to the following links to learn about SQL Pattern,
Drupal stack exchange questions
Dev mysql doc refman
Docs oracle com cd
Create your own customized data fields and set their properties according to your requirements.
Hope this helps you.
Thanks,
