Need free article uploading software
I want to upload my articles in my website to promote my website.
I want to submit my articles fast and gain the most traffic by using the uploading software.
Where i can find the free article uploading software?
Best Answer by Samuel J Melendez
Answered By 5 points N/A #189945
Uploading an image or a document to your website will depend on how did you do your website.
If you do it using the HTML programming then there are programming codes that you can insert on your program to be able to view your article on your website.
If you are using a website builder such as weebly or yola, they have an in-build tool which you can just simply click to insert your article.
But if you want to just upload your file, try the Scribd and you will be given a link to your file.
Answered By 25 points N/A #189946
Hello Mark E Ward,
I don’t understand why you people going for free software?
Free software is not good for professional use.
Because there are many limitations for using the freeware.
If you are looking this for professional task, I will suggest you go for the professional software.
If you are still looking for the free go to the following site: Free Article Marketing Robot.
