cow anedith
10 points
Posted on - 02/13/2013
Preferably, I want an easy to use AVI batch BMP converter. I need to be able to convert AVI to BMP images that are still high quality photos and doesn't lose its resolutions during the process. Where can I find some free software that is an AVI batch BMP converter?
Need free Avi batch bmp converter
1. Total Video Converter is a total-featured conversion software that can support almost all video and audio and image formats. It does the inter-conversion without compromising on the original quality of the source media.
2. Xilisoft converter compatible with Windows OS versions starting from XP sp2 onwards and has the ability to inter-convert media without compromising on its high quality.
Hi there,
There are several software solutions that will make a quality conversion from AVI to bmp images. However, I'd like to suggest you the one named Martik AVI to BMP. It is a free and pretty straightforward software that will give you plenty of options and will turn your video into a quality image.
There are also some online converters that maybe even a better choice if you don't mind uploading videos, like the:
