sammy noel
50 points
Posted on - 08/25/2012
Hi Experts,
I am in need of a free code for video slider. I tried the many free code on the internet but they are not working. Can anyone tell me a free code for video slide show? I need to create video slides for a company. I need an executable code. Thanks.
Sammy Noel
Need free code for video slider?
there Sammy Noel. In my opinion you should first know how to use jquery before looking for a code so you are sure that if you see the sample code you can simply figure out what's going on to your codes.
Because every programmer and coder are using different variables so copy and pasting is not that helpful. Ok if you are sure about how to code jquery you can watch this video to get some tips on how to solve your problem.Â
