Need to get information about Server on rental basis
Dear All
Can anyone give me any idea of Server on rental basis? Is it possible if we want to upgrade memory on server box rental basis. How much does a normal server cost per month?
Dear All
Hi Nood,
Renting a server is a good idea for most of us. Especially if you have limited budget then renting would be the best idea. You can upgrade the RAM and memory any time but you have to pay extra cost for this. And if you have some budget and want to go to a long way then I would suggest you to a server of your own. It is hard to estimate the rental cost as different provider has a different cost plan. So you can choose the specification and ask for a quote to some provider.
