I have been working with some animation projects which required some stimulation and my project leaders wanted to use all images in .svg or .svg format and problem is that I have all images in gif and I want to convert them into svg format I need a gif svg converter to convert my images ?
Need a GIF SVG CONVERTER
Hi Sophieissabell,
There are many free converters you will find on the internet but most of them contains a virus or doesn't work properly.
There are also many expensive converters which will cost you money but I have figured out an easy solution for you, you can convert your images in free from an online website.
This is the link. It works 100%.
Thank you.
Hello Sophieissabell,
It's very easy to convert GIF image to SVG file it’s a kind of online converter, please go to the following link:
Now upload your GIF file & change pixel, color, Enhance, DPI as you want & just click convert. It's done, easy and simple.
There are many software available on the web, you can buy those, but the best way to convert GIF to SVG is the above link.
And it’s absolutely free.
Hope this will help you.
Thank you.
