Need a good Linux vcard editor to edit contacts?
I have my contacts backed up in the form of .vcf file. I need a recommendation for a good Linux vcard editor so that I can edit the contacts and then put them back again in a new phone.
I see that you have your contacts backed up .vcf files. To edit these contacts you need a vcard editor or a vcf editor. There are a few editors available on the internet that you can download for free and then edit your contacts. Before you download an editor make sure you check the compatibility of the editor with your system. If the editor is not compatible with your system then you may not be able to use the functions of the editor.
The commonly used vcard editors are:
1. TuxMobile – You can get it here – http://tuxmobil.org/vcard.html. It is one of the widely used vcard editors.
2. Open contacts – You can get it here.
See the screenshot below:
3. VCF viewer – You can get it here.
Notifications
