Need a good partition suite for Dell studio with Windows 7 (500GB)
I bought a new Dell Studio with Windows 7 with 500GB hard disk but I have not got any partition utility with it. Which partition suite should I use which will give me the maximum advantage of space?
Answered By 30 points N/A #156374
Hello.
There is no need for any partition suit for dell laptops running windows 7 as their operating system.
If you want to do any partition then follow the below steps.
1.       Press windows + r keys simultaneously.
2.       In the run type diskmgmt.msc
3.       A new window appears with all the information of the disc space and partitions available. See the below image.
4.       You can make partitions of your choice and can be done easily.
Thank you.
