Need a good software for recording screen region
Hi everyone, I am facing a problem, I want to record screen region of my desktop but I can't get any software. Please suggest me a good software of it, thanks.
Hi Moses V Patterson,
There are many screen recorder software in the market and online. You can search on Google for this type of software there you will get many websites and you can download from them. Before purchase any software, download trial version to know is it easy for you or not. After selecting any one if it is not easy for you then you should learn about that software and then you can work with that, It will be long process. So, be careful before purchase. For your help I am giving a web address where you will get a video recording software.
http://www.screenrecordings.com/
It is easy to me that’s why I am giving you but again check before purchase
Have a good day
Notifications
