Liam Sam
10 points
Posted on - 08/31/2012
Any of you know a good source where I can learn decoding dvd? i need to learn decoding dvd so I can burn it and can play all videos in my windows media player? I am searching for a good source where I can learn decoding dvd.
Need a good source where I can learn decoding dvd
Here is the source from where you can learn decoding dvd http://dvd.brothersoft.com/dvd-rom-decoder.html. You know that a movie downloaded from the respective website needs to decode sometimes to make it compatible with the Windows Media Player or burning with a burner.
For this purpose you need to use decoder software that can make the necessary measures to make it in the position you want. This is a helpful tool for the purpose.
The compatibility issue is solved here. Thus you can learn and get decoding software to play a video in your Windows Media Player which needs to be decoded for some reason. Â Â
I hope you understand it.
