I don't know anything about coding . But the Google map that is build on java script solution. I need a Google map codeplex video which will display about using the basic SharePoint list. Please help me to find this video.
You need not worry about your coding skills to use a google product. Google gives you all the resources to learn before using their product for our own purposes. The video regarding How to use the Basic Sharepoint of Google Maps can be found here. If your doubts persist after watching it you can follow up by reading their description on using SharePoints.
Share point can be used by simple drag and drop, all you need to understand is its functionality to use it.
1....
