Hi experts,
I have just started a new work, where I have to maintain all the CSS and HTML files.But now, the code spans most probably 5000 lines which weight is near 150kb.So i need syntax cleaner to check the codes.
Need a great syntax cleaner for checking CSS codes.
You can use online CSSCheck or CSS Lint, that is checking syntax in CSS. Here is the link for CSSCheck http://www.htmlhelp.com/tools/csscheck/ You can direct input the style sheet and check. CSS Lint http://csslint.net/ is an online tool that helps web developers to find errors in CSS code, using syntax checks and rules based on common errors and signs of code.
Alternative, you can buy HTML Validator, download from this website: https://www.htmlvalidator.com/ It’s powerful software who is specifically designed to check HTML, CSS and more other.
Williamson Mellisa
