Need a guidance on RTView Enterprise Monitor 1.5
Why do I use this? Where do I use this? What is Customize EMS Alerts? Can I use this only administrative area? What is automatically generated topology view? What is Monitor Connection Count? How does UXMON work? Give an overview about Monitoring and management system. Has it Html5 Trends, Charts? Thank You
Answered By 0 points N/A #188544
         The RTview enterprise monitor has easy to use and easy to implement monitoring, provide health state of end to end for our most business critical applications and softwares that support middleware, virtual machines and host network.
         The RTview enterprise monitor provides framework leveraged specialized Tibco, ibm and other element of our deployment which can pick to tailor the scope of the enterprise monitor to your specific needs.
         The RTview monitor provides the ability to intelligently and advanced visualization of monitoring the number of desperate elements and application owners, enterprise architects and IT operations.
