Need a hard drive with dual interface thunderbolt port
Hello.I need a dual interface thunderbolt port with usb 3.0 support.They are some online but i need the one that have the most diversity and can connect to upto 5-8 desktops.I need some directions.
Answered By 0 points N/A #132625
Hi Michael,
I will recommend a hard disk from Lacie products for your consideration. You can buy Lacie little big disk thunderbolt series. As per your requirement this device can help you a lot. It has 3 products 1TB, 1TB(7200 rpm), 2 TB and 240 GB(SSD). Interface is dual with 10 Gbps specification. It can be easily connected with upto six thunderbolt devices. For daisy chain technology data transfer rate can be varied between 190 mbps to a maximum of 800 mbps. The nicest thing about this is it has a three year of warranty tag.
If you want a portable one then you may wait for the latest release of Buffalo. This is the world's first portable HDD with the USB 3.0, thunderbolt port and dual interface technology. Although the Buffalo technology has not given much information about the upcoming product.
Otherwise you may use an adapter for this purpose. Thunderbolt adaptors are low priced and have versatile compatibility.
Lacie products
Thanks
